Gstewart
- January 1, 2015
- Pittsburgh, PA
- 1995 Explorer (EB)
Why is this alternator circuit different from all the others and all the diagrams? The regulator does not connect directly to the field connection.
Bought this 1995 Edie Bauer Explorer in May 14. Garaged all it's life. Everything looks like new. It doesn't normally get much use so before a long trip we took it for a 150 mile trip to test it. Twice on the way back the voltage meter dipped down and the battery light came on for about 10 seconds. I replaced the alternator. After turning in the core, the new alternator quit on the way home. Went back and got another one, but let them talk me into buying a battery too. After turning in the core that one quit on the way home too. Took it to local shop and they decided that alternator was bad and took it back to the parts store, where they checked it on their machine and agreed that it was bad. Now it is acting up again. If I take it for a drive the voltage meter is almost sure to dip down and the battery light come on several times during the trip. I have checked the voltages on the alternator and compared them to my identical looking alternator on my 94 Ford Ranger. The voltages are identical on the two outside pins (3pin connector) (12v) and the center pin has 7.48v (while idling). The only difference is that on my Ranger the center pin jumpers right over to the field connection on the alternator, but on my Eddie Bauer Explorer the white and black wire disappears into a bundle and then comes back to the field connection. This "little nuance" does not show up on any wiring diagrams that I have seen. All the diagrams show the jumper directly to the field connection. All the other cables and connections seem good (grounds and hot wires). The only one I can't really check is the black and white wire that should be a jumper but in reality goes into the wire bundle first. For all I know that wire goes through ten things before it comes back to the field connection. One more thing that could be related or not. Sometimes the idle is a little low and pressing the gas pedal results in hesitation. Then during the hesitation moment the meter dips and the battery light comes on, however who could blame an alternator for that. My other problem seems to not be related to the hesitation events.
Anyone have any idea about where that black and white wire could be going when it leaves the regulator on its way to the field connection?
Thanks for your help.
Gstewart
Gstewart
