Always on cigarette lighter | Ford Explorer Forums
elkram_b
Location
Massachusetts
MA
2013 Ford Explorer XLT
Sorry if this has been asked before, I used search but was not able to find the answer...
I installed a dashcam and have a cigarette lighter hub with a few USB devices. What I've noticed is that the dashcam and whatever is plugged into the cigarette lighter stays powered on.
I will be away from the explorer for about 2 or 3 weeks, just wondering if the explorer has a mechanism where it will cut power eventually to the cigarette lighter, etc. if it senses it is getting to low to start the vehicle? Or will it continue to drain the battery to 0 leaving me to jump start the vehicle?
I have a '13 XLT
Power to the cigar lighter will go away when the battery dies.
Is this the truth?
It's impossible for us to know, with so little detail from you. WHERE is this cigarette lighter socket? Is it really a lighter socket, or is it a power point? Which fuse is it on?
This is really a design flaw...
What flaw do you think the designers should have avoided? They couldn't know if you were gonna plug something in & leave it turned on for weeks without keeping the battery charged. That's operator error - not a design flaw. Historically, Ford vehicles have usually been designed with always-on power sockets, so they're not flaws. That's just the way Ford builds them.
It is the front cigarette lighter below the radio. My explorer is all stock, no modifications.
One would think that there would be a fail safe in place so if the battery got below a certain level it would kill power to all cigarette lighters or accessory devices that are not required to start the vehicle.
Get one of these power cables that have the correct plug for your dash cam. They shut off when they sense low voltage. I've had one for a year and they work. Easy install fuse taps so you don't have to modify factory wiring.
Reliable, low-voltage protected power for dashcam, GPS, or other in-car electronics; compatible with a wide range of devices. Check it out on Amazon - you won't regret it! https://a.co/d/focJK1C
Not a "design flaw" at all, that's the way Ford has done it on most of their vehicles for decades.
And, owners of the newer Explorers that do have power points that time out ***** about it working that way instead of how yours work. IIRC, they changed it around the 2016 MY on the Explorer.
That's a power point. Modern vehicles don't come with cigarette lighters unless it's listed as an option.
Read your Owner's Manual re Auxiliary Power Points on page 200 of the 4th printing. That may answer some questions.
From what I know about the older Explorer, I don't think it has any smart cutoff for the lighter. Like, it won't shut off power just because the battery's getting low.
So yeah, if you're gonna leave it alone for 2-3 weeks, you're probably looking at a dead battery or needing a jump start when you get back.
I have ordered one of those 16 pin type A plug adapters that adds a USB connection to the back of the rearview motor. I think this is my best bet as someone suggested.
I'm not sure what you mean by"rearview motor", but some members hook up a battery tender to the battery when the vehicle is left for an extended period.
