Im replacing the front hub/bearing assembly on the passenger side of a 1995 ford explorer 4x4 and I was wonder if there is a seal that goes between the bearing assembly and cv joint or between the cv joint and the knuckle to seal off the bearing? If not how does it stop all sorts of dirt from getting into the bearing assembly. Basically is there a seal for the back of the bearing assembly and the knuckle
