Oh the wiring for the head unit?
Thats pretty easy:
There should be a harness that came with the head unit (A)
And another harness you had to buy to fit your car (B)
Set A and B next to each other, open your owners manual and the piece of paper that came with harness B and start matching up colors.. then splice.
IE: Find "12V Memory" on both papers, it will tell you what colors they are, and then connect them. Most of the colors will match directly, its just always good to check.
The 12V memory is probably yellow, 12v ignition will then be red, black is ground,
Then you should have 4 pairs on each harness
1) White, White/Black
2) Gray, Gray/Black
3) Purple, Purple/black
4) ?? Green, Green/black
Those are all your door speakers, they should match color to color with each harness.
On the harness that came with your head unit, you'll have a blue OR blue/white for a power antenna... the other blue or blue/white is the remote wire for an amp. Then you'll probably have a thing orange/black thats illumination.. that one can just be capped.
I think i got it all.... any questions just let me know
