Annoying serptentine chirp... any suggestions? | Ford Explorer Forums
taylormanson
Cleveland, OH
95 Explorer Sport
Annoying serpentine chirp... any suggestions?
The belt was changed just before I bought the car (around 100k miles and I have since put an additional 8,000 on it). Belt Dressing spray takes the chirp out when I spray it in (usually in the morning) for the day, but it seems to start up again the day after or a few days after. I initially thought it could have just been the belt contracting and being cold because it started in the winter and as I would drive the chirp would gradually dissappear (as the engine warmed up). But... now that it's spring and the ambient outside temp is around 60 degrees or so here, I've still been noticing it. Any advice?
Sorry, posted this in Under the Hood by mistake...if a mod would bump it over to General it would be appreciated before I get flamed :) Thanks.
i have the same problem when its humid outside. when it rains or is muggy, the belt starts chirping. the only replacement is getting a new belt.
You can try silicone spray. With the engine running, spray the crap out of both sides of the belt. If this doesn't work your only option is to replace the belt.
I had the same problem when I replaced my Ford OEM belt with an aftermarket belt. I returned this belt to Checker Auto and exchanged this for a higher cost belt. Same problem. Finally, I ordered a Ford belt from fordpartsonline (cost about $18 + shipping) and this took care of the problem. I've found that in some applications the Ford parts just work better than aftermarket stuff.
Had a similar problem that turned out to be the idler pulley bearing. It was pretty inexpensive and only a 2 skinned knuckle job to replace.
