Another ABS thread | Ford Explorer Forums
Another ABS thread
kenny80
clinton il
04 explorer
Ok got an 04 xls 4x4 104xxx miles. Abs light is always on and often engage when stopping, which also was i think causing 4x4 to kick in and had 4x4 lights on. Ive pulled fuses from 4x4, changes both front hub bearings and all 3 speed sensors. Abs still illuminated and engaging. Any ideas? (All tires stock size and properly inflated)
Have you pulled CEL codes to see what computer is saying is the error?
No i tried to have AutoZone do it but they said they couldnt.
Check the connectors for bent pins.
Ok i will check that one of these days when the rain quits, will also look around for someone to pull codes. Thanks.
