00sport4x4
- September 16, 2002
- Elyria, OH
- 2004 Ranger FX4 Level 2
Ok Ive used the search and found info on "front end squeak" but not quiet my deal. My left front started squeaking last night, "sounds like an old spring" when I hit bumps or turn the wheels, sounds alittle worse when turning right as the left gets more weight tranfered to it. I sprayed silicone and grease on the all the front bushings including the sway bar links, checked the ball joints they seem ok. Its around 25-32 degrees here so I thought maybe some water got inside something and freezed but the 40 miles I've put on it should have warn that out. I'd really appreciate your thoughts on what could be causing this.
