fiction1990
- April 16, 2006
- Jamestown,ND
- 03 XLT 4x4 4.0
2003 xlt with rear air. I have read through the forums and think I have tried all the suggestions. I have flushed the sytem and both cores (had good flow) I have changed the thermostat, the heat valve by the valve cover, fixed the blend door motor and I'm pretty sure the door for fresh air works. The problem I have had and still have is that it takes for ever to heat up. I can remote start it and after 18 minutes when the the timer runs out I dont have heat or at least very little heat (not enough to even defrost the windshield).
If I go up on the highway it will get nice and warm until you come to a stop light and then it cools off again (not cold but a signifigant difference in warmth).
Please any ideas on what to change or look for?
