skibender
- December 4, 2003
- Franksville,Wi.
- 98 XLT
98 SOHC 4x4 115K miles Just purchased.
I have the typical erratic cold idle. No CEL's. Checked volts and ohms on IAC-everything good. Cleaned twice. No help. Then decided (by this forum) it could be the o-rings in the lower intake. Called Ford and this fix (M0012) wasn't done on my vehicle. Also checked volts and ohms on MAF and everything good. Cleaned MAF also. Before trying to change o-rings, tried starting truck (when cold) with MAF disconnected. Idle pretty good. Much better than with it connected. After it warms up a little (2 minutes), it wants to die out - which I'm not concerned with right now. My question - with MAF disconnected and good idle, does this mean MAF is bad? Or, is the MAF disconnection masking a leak on the o-rings? I want to get ideas before throwing money at the MAF sensors. I want to fix this but if I don't have any luck, will it hurt the truck leaving the MAF disconnected? I get 3 codes. 2 are for the MAF inputs and one code that said bank2 lean condition. Any help would be greatly appreaciated.
