RIGLEY
- October 11, 2010
- Windsor, Ontario
- 2004 4x4
First off i understand that their is a million posts on door latches but nothing that im curious about.
Yes im another owner that uses the dome light in the down position for the last 2 years to kill the interior lights until i hit 20 mph then they will go out, but the light on the dash stays on to show a door ajar aswell as the airbag light.
i have tried the wd40 trick and spraying into the locks to no result, today i worked on the truck to see if i can figure out what door it is..
well with the key in the ignition and in the ON position i open the driver door and the truck will ding ding ding, so im opting that door out !
i cant seem to figure out what door is at fault, so 3 doors to rip apart to have a look. i notice that their is 2 wires that go to the switch latch unit, one black and one green with a stripe of pink or so.. i have tested the black wire at the end switch side to cont to an inside ground and all is good.. when i got to the passenger rear door i noticed that the other plug wire that is on the latch was not on, so i thought bingo here it is, plugged it back in and still the same problem...
question,
1 what is the other wire (green) for on the latch ? (12v+)
2 what is the ground wire used for ? meaning if the latch is damaged can i rewire to show the door always closed?
3 is their a way to figure out what door is the problem ?
thanks all in advance !
and im sorry if this post is somewhere else i could not seem to find the information that i was looking for so that's the reason for this post !
question,
