I have switches in four places in my car.
1. Right by the stearing wheel. Heres what i did. If you look, you will notice that there is a plastic sheilding right around where your knees are when your sitting in the drivers seat. This is the piece of plsatic directly below the stearing wheel. You can take this piece off by unscrewng 3 or 4 screws by the bottom of the plastic (requires you to literally stick your head under your drivers side dash. Once this piece of plastic is off, you can then find a plce where you want the swtich. There are some complications however. There is a big piece of metal directly under the plsatic. If you want to mount a switch easily, you have to have the switch mounted prety close to the stearing wheel. This is so that there is enough room for the swtich. (there is about a 1/2 inch gap between the stearing wheel and where the metal starts (plsatic covers this gap, therefore you can drill a small hole and put a metal flip switch in). If you want to mount the swtiches a little ways away from the stearing wheel, you will have to dremel out a piece of the metal to fit the swtich. I have not done that yet (and don' t plan on) because i don't feel like messing with that.
2. The second place where i have mounted switches was in my glove compartment. The swtiches in there control all my strobes...cause i don't want any of my stupid friends flipin the strobes on "by mistake" when im next to a Cop
3. The third place i have mounted switches is by the front passengers seat. Not the best aceesible place for switches (to turn them on and off from the drivers seat) but there is enough depth to mount square or circle lit switches (i know that for the models of explores below the 96, there really issn't to much space for swtiches in this location). You can see a pic of the lit swtiches here -
Dead Link Removed (if the link doesn't work, click and paste - geociteis has been acting gay lately)
4. The fourth and final place i have mounted switches, is right by my right foot in the drivers side seat. If you look at our center console, and follow the plastic to where your feet is, there is a slack where nothing "importaint" is. That way you can drill some small holes and stuff a few swtiches there.
Hope this helps, sorry its so long!
Carl
