jrford
- March 1, 2005
- Birmingham, MI
- '10 Sport Trac
Please bear with me, I have searched and read, searched again till confusion set in. .
. .but what’s the best way to improve the bass on an Audiophile in a 3rd Gen? To paraphrase I’m not looking for Rap bass, but rather Jazz bass, it sounds now like News bass (none). Some songs are fine but others I have to sit in back to hear it and when I do I hear some midlevel sounds coming out of the sub (vocals). Its as if the bass unit is not putting out the right volume. I also have the DVD/Steering wheel controls so I don’t want to get a new HU/Amp combo, its more for Jazz or classic rock.
The story is when I had gotten the truck it came with the base radio, which sounded like poo under water, so I picked up ($15 each) some Polk EX357 5"x7" 2-way Speakers, which sounded a lot better with the base radio but still very weak on the bass. So I pieced together an Audiophile system 290w and mounted the Factory SubWoofer unit, and wired it all up. The Polks lacked any bass as if there was a hole in the sound around 100hz, so I replaced the Fronts with Boston Accoustics SX85 and went back to the OEM rear door speakers (25w at 4-ohm). I might say its better but still weak on the bass.
The Audiophile Subwoofer is a 8” 2ohmX2ohm and 45wX45w in a .5cuft enclosure, its only feed is a +/- single source, so it must be bridged amp?
Now the questions thanks for reading so far, . . .
Does anyone know the cutoffs on the Audiophile’s?
Power wire to small? When I hooked up the Sub Batt power I pulled it off the Radio power which looks like 12-14ga wire so that this wire is running 290w, is it too small? Would running the sub its own power wire help 10-12ga?
Bigger amp? In looking the amp maybe the way to go, but its got to be small, the OEM is like 3x7x1. With a different or bigger amp I would also be able to customize the bass level and cutoffs, which might help. I have found Boss Amps that might do it? Any suggestions?
New Sub Speaker? OEM is a 8” 2ohmX2ohm and 45wX45w in a .5cuft enclosure its kinda hard to find an exact match. JL Audio makes an 8”4-ohm W1v2. I fear that if I get just the Sub speaker I’ll still need a bigger amp? Any suggestions on this?
Both? Sub Speaker and Bigger Amp would be about 200 clams . . . .i’m thinking that’s the way to go, unless someone knows a way. . . .
Thanks for any ideas, or any threads i missed, and reading this. :scratch:
Jim.
Jim.
