Anyone running 33x12.5r15's on 2" BL & 2" SL? | Ford Explorer Forums
easnoddy
Bogart, GA
1997 Sport 4WD
Sorry this is my 3rd or 4th new post in 2 days, but as I said before, I'm trying to get the info ASAP so I can do the lift next weekend and order the tires.
I really want the minimum lift I need to run 33's with no rubbing. Will only 4" (2" BL/2" SL) be enough to run the tires with only the trimming of the little tabs on the front fender flares? If not I'll go ahead and do the 3" BL. I need advice on the decision. TIA!
How wide of 33's are you going to run? WHat backspacing is your wheels gonna be? That will make a difference. I would do the 3" BL Im running 5 inches of lift and still rub with 33's.
I don't think you can run the 12.50's
i think you can run 33x10.50's with 2"BL and 2" suspension.
I'm going to run 33x12.5's on wheels with 3.25" backspacing. Sounds like the 3" is the way I NEED to go. Thanks!
do a search for 3" BL's they are a little more complex to put in than 2"
