anyone tried this | Ford Explorer Forums
anyone tried this
ranger91
gardners pa
91 ranger stx
i was wondering if anyone has tried to make an 01 explorer sport have a manual locking front axle instead of it always turning? i am looking into a locker for the front axle and with driveing on pavement that wouldn't work to good unless i can unlock the front axle. any ideas?
First off, an auto locker (like the aussie) will have absolutely no effect on the truck when in 2wd. Since you don't use 4x4 on pavement, you won't notice it is there.
If you are set on manual hubs anyway, you will end up with a weaker front end. The advantage is that if you break a cv joint, you can unlock the axle and drive home. Again, you sacrifice strength and risk blowing the manual hub right of the wheel.
Lots of people have done this on rangers, some on explorers.
You will need the following;
98-00.5 ranger halfshafts, and wheel bearing/hub units, and AVM manual hubs. The halfshafts and wheel bearing/hubs can be used ones from a junker if you think they are in decent shape.
The problem is the hub design. It's not like the good old manual hubs you used to find that were harder to install (because they were designed better). You literally unclip the auto hub, pull it off, and snap the new one on. It's not held on by any nuts/bolts/screws, just friction clips. A TON of people with rangers have had problems where the hubs actually pop off from the torque while using 4x4. This is without a locker. So I imagine with the added stress of a locker they would be popping off left and right. If your wheel center has a big enough opening, you might be able to ghetto rig a hose clamp around the clips to keep it on...?
I had the AVM hubs on my 98 ranger and they worked okay for me, but I read of tons of people who had them fall off.
Here is what the factory automatic vacuum hub looks like...
You can see those clips are all that holds the hub on. The whole thing is plastic.
The avm installed. Don't have any close pics of it, but it's design is basically the same, only you are manually sliding the inner and outer splines together. Still weak plastic.
