PotatoExplorer
- August 15, 2016
- Location
- USA
- Carlisle, PA
- 2008 Ford Explorer Ltd.
Whoa, that got me all types of confused!
Is this a common cause/effect problem that allows for misfires? I've always noticed on my cylinder 1 injector, the fastener clip that *clicks* when you press the two ends together, was broken. When the two ends were pressed together it felt tight enough (in my opinion) to not have to really worry about. Anytime I pop the hood I normally go through and press down on all the plugs on the COPs and injectors just as a normal routine check (and maybe a little OCD), but never felt any play. This is interesting because my Forscan said I had a misfire in cylinder 1... hmmm!
The injector code is most likely an issue with the plug most likely the clip is broken. Try to fasten a zip tie around the injector and plug to keep it tight.
