Aussie locker | Ford Explorer Forums
Aussie locker
bilchap
south mountians of NC
Does anybody know if the cross pin in a stock dana 35,is strong enough for the aussie?I seen somewhere on here that the 8.8 pin wasn't strong enough.Also seen that some people had problems with aussie set-up.Whats up with that?
...I haven't had any problem with mine...
..It seems if it is not set up per specs, people have problems...If you do a search for Aussie on here, you will see this has been discussed several times...;)
All sounds good,but you guys with aussie lockers,did you use the factory cross pin or an aftermarket one?
I had to use an aftermarket pin because I am running 456 gears. almost 4 years 3 trips to CO one to ARK, and countless weekend wheelin trips-- no problems yet.
