And I'de swap out the 12 for 14 guage wire. See:
http://www.explorerforum.com/forums/showthread.php?t=28683 (post #2) and make your own decision. Me, for most all lights in the front grill area (130 watt included) use 14ga wire. Only reason to use heavier guage is if the wire length is longer.
The 12 volt source wire going to nowhere is if your switch needs another source to light the switch. Hook that to your interior lights if so.
Hmmm, interesting link. While it is a GOOD chart, he then negates EVERYTHING he has said at the end with this statement:
Wire sizes for lighting is more critical than for other applications — The rated output of any lamp is figured at 13.5 volts, not 12 volts as you might expect. So with a ½ volt drop you are at 13.0 volts. And at 95% of the rated voltage, you are only putting out 80% of the rated luminous intensity - for a 100 watt lamp that’s only 80 watts!! Get what you pay for and figure to the high side when you are sizing wire for lighting.
I am going to expand on this a little bit, also sorry Bill if you feel I am stepping on your toes or anything. I am just letting everyone know what I have learned and honestly mean no offense by it.
First off, I use this site here OFTEN for calculating voltage drop for wires:
Voltage Drop Calculators
The site has four different calculators and I usually use the second one as it is the most useful for vehicle applications. It is called Any Voltage Voltage Drop Calculator, and I use it with THESE settings:
Material = Copper (change to alluminum if you are using alluminum wiring)
SelectPhase and No. of wires = 1-phase - 2 Wires
Enter Voltage = 14.0 (This just fills in the output voltage, it doesn't change the voltage drop value).
The rest I fill in with the relevant needed for calculation:
In this case I chose a Circuit Length of 6-Feet, the Amperage was 21.66 (as calculated before) and then varied the Gauge:
The results are:
18 Gauge: Voltage Drop = 2.07 Output Voltage = 11.93
16 Gauge: Voltage Drop = 1.31 Output Voltage = 12.69
14 Gauge: Voltage Drop = 0.82 Output Voltage = 13.18
12 Gauge: Voltage Drop = 0.51 Output Voltage = 13.49
10 Gauge: Voltage Drop = 0.32 Output Voltage = 13.68
Its Effect on Light output:
In this section, I am using a bulb that has an output of 1200 Lumens at 12.8V. All calculated Light outputs are based on that. The last entry is the theoretical maximum (assumes 0 voltage drop).
18 Gauge: Output Voltage = 11.93 Output Light = 944.60 Lumens
16 Gauge: Output Voltage = 12.69 Output Light = 1165.30 Lumens
14 Gauge: Output Voltage = 13.18 Output Light = 1325.50 Lumens
12 Gauge: Output Voltage = 13.49 Output Light = 1434.52 Lumens
10 Gauge: Output Voltage = 13.68 Output Light = 1504.39 Lumens
Theoretic: Output Voltage = 14.00 Output Light = 1627.43 Lumens
Lastly, time to compare the percent differences from 14.0V for voltage and light output:
18 Gauge: %Diff Voltage = -14.79 %Diff Light = -41.96
16 Gauge: %Diff Voltage = -9.36 %Diff Light = -28.40
14 Gauge: %Diff Voltage = -5.86 %Diff Light = -18.55
12 Gauge: %Diff Voltage = -3.64 %Diff Light = -11.85
10 Gauge: %Diff Voltage = -2.29 %Diff Light = -7.56
Personally, I would like to keep the Light output drop under 10%.
Note: This does work does NOT apply to devices like HID ballasts as quality ones maintain a precise output voltage no matter the input voltage. Instead, for a relay harness for HIDs, I usually just use 14Ga or so and call it a day as that has been shown to be a high enough Gauge to handle the initial start-up current (which can over 100-200A for a few milliseconds).
This makes me want to put together a rough website based off of the aforementioned calculator that will allow a user to see a calculated light output based on wire gauge. Time to see if I can make it work. If I can Bill, I will post it and maybe you can use that link to show people. That is I haven't pissed you off with this long lecture of a post.
