you need a rwd version of the 4r70w
I have two of them downstairs
You need one from a 98 or newer so it matches your trucks solenoid wiring and digital range sensor
There is no crown vic in 1998 and all other fords after 96 use the 4.6, so should get your trans from a 98-01 Explorer 5.0 RWD
4.2L V6 F150 from 98-2004 would work, the 4.2 has same bellhousing as 5.0
The RWD 4r70w
If you are handy you can use any 4r70w that came behind the 5.0 or 4.2 and possibly the 3.8L mustang/cougar and upgrade the solenoids and dtrs to the ones from your 98....but now we are getting ahead of ourselves...... and the early 4r70w (93-96) had issues
