Albino 94LTD said:
I've gotta check the latest bank heists. Dreamr has way to much money.
I wish I had more
But if I budget well I can spread this out over time and it won't seem like that much. Piece by piece things aren't that expensive. Especially if I don't have to pay for labor and fab work. At least no more expensive than a set of wheel bearings which are humming lightly (220 each), and CV axles (310 each) that will likely break one day with the bigger tires and TT.
A solid axle is so much less money to maintain and less worries.
If I had the TTB I wouldn't worry about it all. This IFS is CRAP!
Now if I can just get started and still get in my garage when done.
Though it will likely not happen till at least winter, I would like to start on the axle build-up at least.
I have 80" of clearance from floor to the garage door at it's lowest point.
My truck currently sits at about 74.5" at it's tallest point, so I should be OK after I pull the body lift.
What a waste of money having got it to it's current point only to start tearing it all apart again. Maybe I won't but we'll see...................
If I do, you should let me put the body lift on yours Phil
