B&M trick shift fluid | Ford Explorer Forums
g0tink87
NY
1993 XLT
anyone use this stuff in tranny. Is there anything that would benefit from it being a stock transmission. Im gonna change the fluid and filter and was just wondering is it worth the extra $$$.
If its not worth it is there any fluids out there that are better than others, or maybe sythentic fluids. Sorry I dont know much about transmissions
I used the B&M in my Hotrod Monte Carlo. It had a 700r4 with a shift kit, dont know if it helped , but i never had any problems with the tranny so.....I fealt pretty cool though with blue tranny fluid. lolol
I really loved the Trick Shift in my AOD, in my 91 Mark VII. It's great fluid, but not really ideal for the newer transmissions. I have an extra case but I won't use it in these newer Fords I have. I'll save it for the older pre-electronic transmissions.
The best fluid you can use is the aftermarket synthetic fluids, like Amsoil sells. Many have reported improved gas mileage with it. I have the Amsoil ATF myself ready to go in, but after a last dropping of the pan, soon. Good luck,
I'm agreeing with ^^^^^^
The B&M trick shift fluid is basically a different grade of transmission oil, like Type F (the old Ford standard) which makes the clutches grab harder, but shortens their life. I'd just run a good grade of synthetic, add a cooler and an external filter (do a search on the forum) and leave it at that.
ok for now i just picked up couple qaurts of regular fluid. Next time I do it Ill probably use a sythetic. I need to do a quick fluid drop and replace. Long story.
I would stick to a high quality synthetic ATF such as Amsoil.
Good luck ....
Dead Link Removed
