Bad Reception? | Ford Explorer Forums
Bad Reception?
WolfPack
Northern Maine
1998 Eddie Baure V6
Within the past two years it seems that the reception on my stock radio is deteriorating. The static is very bad at times, sometimes I cannot even get a station in.
Thinking it was the stock unit gone bad I have switched head units twice, both with new aftermarket quality brands I.G. Alpine, JVC.
I know the reception is not as bad since I can get the stations clear in the same area's from a another car I own.
I checked and know the antenna wire is hooked up, what else can I check? Grounding straps and I believe there is some kind of piece ford uses in the engine compartment to reduce noise interference form ignition components.
Any help is kindly appreciated
I am sure someone here must have had a reception issue. This one is not with the radio, as I have had three different units in the vehicle.
I know there are grounding straps and other devices in the explorer to enhance reception can someone help with this?
I thought there was some type of resistor in the engine bay to block RF noise?
Maybe check out the antenna, ground, and the wiring to and from.
Thanks I will do that. I know there are at least two grounding straps, maybe thats it. :chug:
Im starting to have this same problem too..
I had the same problem on my 1996 Ranger, changed radios, no improvement.
Now, 1996 Explorer, same problem. Mostly isolated to the AM band.
There is a little noise supressor attatched to the coil pack(s), with a single wire plug. It gets it's ground thru the coilpack screw. I wonder if they ever fail?
I ran a 10 gauge ground wire, from coilpack bracket to the radiator support.
Just a thought.
Interesting thread I like the idea about the 10 gauge grounding strap can you elaborate on this or post a picture? Did running the new ground clear up your reception?
Also I wonder if the noise supressor on the coil pack you spoke of can be replaced?
No, it was mainly for performance-grounding the coilpacks was my objective
I have no radio interference right now---I have no antenna!!
All I did was drill and tap a small hole into coil bracket- 10 guage wire with o lug at each end, secure to radiator mount and coil bracket.
I would think the supressor is replacable--
