Ball joint replacement success??? | Ford Explorer Forums
windfreik
utah
92 4x4
Through the help of the sticky in this forum, I tackled this job after the shop quoted me $350. 92 ford, no ABS in front, so fairly straightforward. However, I went to put the knuckle back on and i put a bottle jack underneath the lower ball joint to push up and hold in place while i tightened the nut. Went fine however I wonder if it is seated properly as there is about a little more than an 1/8-1/4 space between the rubber sleeve on the lower ball joint post and the frame. Should the post be all the way in so that the rubber sleeve touches the frame? I tightened the lower ball joint nut to spec but it still doesnt pull the post all the way up to touch the rubber sleeve...
Any ideas?
thanks for the help :thumbsup:
