BExplorer
- April 9, 2000
- Mirabel, Quebec, Canada
- 94' XL 4x4
I ran to the local alignement shop today and found out lower ball joint had took is retirement. I did a search on ball joint but still have some questions? 1-It says I can use a vise to press out/in the joint, do I press over the bolt of the joint or do I have to put some socket on the bolt to press the joint and not the bolt? 2- If the vise is a good way, how do I put it in to press out the joint( a little confused) 3- Is it better to have sealed joint or with grease fitting? 4- Not related to the joint, how do you know if the radius arm bushing are dead(since they seem t break very often. I want to buy the parts today so I can use my 3 day weekend to the maximum (I've done valve cover gasket and convert to manual hub this week of vacation, want to have fun this weekend). Thanks for all the precious help!
