best fluid choice, M5OD? | Ford Explorer Forums
davy crockett
British Columbia
1993 XL
Just in the process of doing the clutch on my '93 X so I'm going to do a fluid change at the same time. Since Mercon III is gone now what are guys using, Mercon V? and is it worth going to a synthetic fluid and if so which one?
I went with Mobil 1 synthetic ATF.
It was a little pricey at like $8 / quart and it took just under 3 quarts..so $24 total, but it shifts quite nice and doesn't seem to foam as bad as the cheaper stuff.
Total quarts/ litres
Was that approx. 3 litres from completely dry ? Can't find the capacity anywhere :-( BN
I would go with synthetic. If you switch the fluids for the whole vehicle to synthetic it should help with mileage.
I believe it's 2.5 quarts.
The way I did it was I filled it from the shifter, left the fill plug open and filled it until I heard fluid dribbling out. Then obviously reattached the shifter.
i use m1 full syn atf, i flushed the entire system and replaced it all, but i got it on sale for 4.5 a bottle cause i bought a case, round 8ea if not in bulk, but works tons better, both the Explorer and Wifes van shifts smoother and temp stays lower
