ChrisJohnsonSCT
- January 8, 2006
- Longwood, FL
- 2000 5.0L
Hi guys,
I am not exactly working on a Explorer, but it's going to use parts from one.
Any help would be appreciated.
This vehicle will use the Explorer Coil packs and the 5.0L Engine Harness/PCM setup from a 1999
Basically this setup is going into a new JMS built Real Street race car that I am working on for the 2006 NMRA season.
My problem/question is this:
Are there any performance plug wires available for the coil pack 5.0L engine setup?
I have seen that Nology has a set of Hot Wires listed for up to 1999......I've never tried this type of wire and would hate to do it without some feedback.
Any advice would be helpful.
The class requires shorty headers and the heads are going to be TFS so my thought is that most likely any performance plug wire should fit if they fit the stock vehicle....also relocation of either coil pack is not a issue if that is the case.
One other thing......I am looking for a few Explorer parts to complete the build along with some spares for the race season (you would be surprised how badly equipment gets beat up).
If anyone has access to the following parts and would like to part with them please drop me a email at: cwj@sctflash.com
5.0L PCM (1 or 2 for Spare 1998-2000)
5.0L Engine Harness (same years for spare)
5.0L Front Timing Cover (with the crank trigger port I still need to buy this)
5.0L Crank Sensor Ring (still need to buy)
5.0L Cam Sensor/Assy (for spare)
Thanks,
Chris Johnson
www.sctflash.com
www.jmschip.com
Thanks,
Chris Johnson
www.sctflash.com
www.jmschip.com
