cherrybomb
- April 1, 2005
- Southern California
- '99 EB 5.0L (R.I.P)
NOx is produced by high temps in the cylinder, doesn't really matter what fuel is being burnt, It's all carbon chain based, just different makeup.
Interesting, I've been doing some googling on this a bit today, and that seems to add up. The jury is still out on the effect of biodiesel on NOx emissions, some research shows that it produces slightly more, some research shows slightly less than petroleum diesel. Either way, diesel engines produce more NOx due to the higher compression and combustion temp.
It seems that the 2009 emissions regulations for diesel will mitigate some of this though, as was stated in an earlier post by kert0307, through the use of catalytic converters, urea injection, and exhaust gas recirculation.
Personally, I'm willing to accept the (apparently marginal) loss in efficiency if all emissions are reduced. Diesel engines still tend to make good power, with "above average" efficiency.
Interesting stuff. Might prompt a follow-up blog post.
