black tranny oil , almost always .... | Page 3 | Ford Explorer Forums
the old v.m was ok (not ruptured) and the oil drained from the tranny hole where the v.m fits , and not from the tube line ,, so , as if the oil is seased some where inside the tranyy and is not circlating during operation (tranny was getting overheated very soon after driving the car )and when i just pulled the v.m the oil got escaped outside ,,the volume of oil which came out is about 3-4 ltrs !,,,?
the car was parked for nearly a month , and there was an oil leakage under the car ( but not so much ) and under the v.m side ,,,so i think it was leaking even when parked and cold , but when i pulled the v.m out , a huge amount came out ...one more note , previously , when i was checking the oil level when the car is off, oil level was very high , and after starting the engine the oil level shows very very low !! so as if the oil is sucked inside somewhere ,,something is wrong in the oil circulation i think causing overheating ,,
b.b , what i mean is that the oil is sucked inside the trany sections not the engine ,because when you switch off engine the level comes back as it was before you start the car ,,,
may be the oil is seased in the torque converter when engine is running , or may be the oil is not circulating back to the place where we can check its level when the car is on , , ,
what do you think ?
