JasmineMcDonald
- September 27, 2012
- Carmel, Indiana
- 2006 Ford Explorer XLT
New to this forum; happy I found it.
I've searched for this issue, and I believe I'm in the right place.
I have a 2006 Ford Explorer XLT 4x4 (I'm not sure about generations as I've seen others write). When I turn my thermostat toward heat, I get the clicking and no heat. As long as the thermostat is in the coldest position, no clicking and I do get the AC. So, three questions, is this likely the heat door/blend door actuator? Is this relatively easy to replace if the only mechanical thing you've done to your vehicle is change a right rear turn signal bulb and added coolant? And, if I can't do it, does $500+tax seem a reasonable price for taking it to Goodyear?
