JStrider
- December 18, 2005
- North Houston, TX
- *RIP* 1993 XLT 4dr 4x4
so the past week I've been getting a vibration at idle, tachometer didnt wobble, just a bit of a vibration at idle and when I was just starting to take off from a stop or going extremely slow like thru a parking lot. figured it was a problem someone had had before, so I searched.
followed the directions albino gave someone else with a similar problem
"Clean your Idle Air Control, Mass Air Sensor, run a can of SeaFoam or B12 Chem tool through a tank of gas and disconnect the battery for 5-10 minutes to reset the ECM. That should help. (do a forum search for these)"
didnt help at all
I was going to make a thread asking for advice tonite. Then I was driving to a restraunt with a friend of mine and we were bouncing ideas off each other, and I mentioned how I was getting warmer then normal when I had the AC on and was stuck in traffic. That got me started thinking about the cooling system, and how when I changed the fan clutch before going to moab I noticed the cracks in the fan and read on here that it really wasnt an issue, that no one had had a fan disenegrate before.
well just for kicks before we left the restraunt I popped the hood and took a look at the fan.
and what do you know I only had 8 blades on a 9 blade fan!
I'm pretty sure thats the cause of my vibration.
Amazingly nothing else appeared to be damaged from the rogue fan blade.
I'll have pictures soon when I get around to replacing it.
Where should I get a new fan blade?
This last one that just lost a blade I got at autozone about 4 years ago, I'm not too kean on getting another autozone one to blow up on me prematurely.
didnt help at all
