Blower on high | Ford Explorer Forums
Blower on high
dan baker
bloomington, indiana
1999 explorer limited
1999 explorer limited, the blower switch is a thumb roller type, when the key is on the fan is on high all the time even if i roll the switch to the lowest setting....could the switch be bad or do i need to replace the resister ?? What do you think guys ....
There is no blower resistor per-say. The EATC HVAC system uses a blower module, which is located at about the 5:00 position relative to the blower motor in the engine compartment. Common failure point.
Thanks for the reply Koda, I removed the module and will replace it with a new one, will update with results soon.... Dan
Make sure the electrical connector is clean too.
