HenryTS77
- March 3, 2011
- Syracuse,NY
- 99 Explorer Limited 5.0
SUCCESS! blower wheel shatterd due to vibration 1999 Ford Explorer LTD
This is an update - I figured why start a new thread so I would just update this one. I went out to the truck after my original post and fired up the heat and heard the blower wheel blow apart Now the blower motor does not vibrate so apparently the old wheel was brittle and sustained some damage either upon taking the motor in or out or during the transfer from the old motor to the new one. In any case now I faced with the problem of finding a replacement. I went to the official Ford site - FordParts and they want $43 and I found a site that had the motor and wheel for around $48 but I already have a new motor. I did see a number of blower wheels for 1999 Ford products for $18 but not the Explorer - would one for the Expedition work? Any suggestions on where to look for just the blower wheel would be greatly appreciated- I have checked CarParts,PartsGeeks,################## and RockAuto.
The other problem is that the blower motor will only operate on high which is what it did before the old motor died. Every time I did searches it came up with bad resistor pack but my truck has the automatic climate control so no resistor. I finally came across the possibility of it being either the blower speed controller or the ETAC (sp?) module with the most likely suspect some say the blower speed controller but some say it is in the glove compartment and some in the engine compartment near the blower so which is it and what does it look like? Also since all the other functions of the climate control work - temp control,switching to various modes ( floor,vent,etc) is the most likely suspect the blower speed control module and if so would it be wise to get it from a pick and pull salvage yard as I read they are pricey??
