Brian_B
- January 6, 2005
- Mountain Home, AR
- 2000 mounty / 56 f-100
Hi all,
Firs let me state that I have no clue where to ask these questions. They could fit into several places. They will all pertain to my eventual swap on the 56 though, so I will start in here.
Let me explain what will happen (I hope) and then ask the questions. It will eventually have an aerostar IFS and a ford 9" rear axle (trading for one now). The front will then have the small ford bolt pattern (5 X 4.5) and the rear will have the truck pattern (5 X 5.5).
Question 1. The aerostar brake disk is the same part number as the 2WD ranger (for that year). Is there an upgrade for the ranger disk that uses the larger bolt pattern?
Question 2. The guys that are doing the SAS swap on the explorers now have the same problem only reversed with the front being the large ford and the rear (8.8) being the small. How are they solving this problem....or are they?
Question 3. Anyone have an idea of the cost to redrill the rear axles, install new studs, and drill the drums on a 9"?
I know that if your fortunate enough to be able to strip a couple of old car 9" axles from certin models you can swap parts around and get it to work. Thats a real long shot around here.
Any other ideas? Preferebly inexpensive ones.
Thanks,
Brian
Thanks,
Brian
