brake bleeding question... | Ford Explorer Forums
WhitEngineering
Windsor, VA
'97 XLT 4DR 4X4 OHV
Easy question I should already know, do you bleed them with the engine running or not? I've always thought not running but never actually heard it said.
not running.
[QUOTE='97 V8]not running.[/QUOTE]
Ditto... not running..
and a third time, not running.
Third times the charm... thanks for the info. Brakes are bled and still working :thumbsup:
Brake bleeding
I did both, beginning with the rear right wheel, then left rear, then right front and finally left front.
First with engine off and then again with it running, i got some air out with the engine running.
Just replaced all the brake lines on my 1991 explorer sport.
regards
Mr Haraldsson.
