Advising Elf
- May 21, 2010
- Arkansas
- 1998 XLT
I recently replaced the ball joints on a 1997 Explorer XLT 4x4, using the very helpful post on the TT&T forum, and in the process, cracked a brake line. The pre-formed brake line is no longer available from Ford, and even if it was, I wouldn't want to put it in because it's in a stupid place (see the TT&T post for more info). I was unable to do it myself, so I took it to a local mechanic who made a new line and installed it. I drove the truck over there almost brakeless, and since I got it back, the brakes have been acting funny.
I replaced the brake fluid and bled them until new fluid came out, but they are still weird. They are a bit spongy, and every once in a while you get a strange vibration and oscillation in the pedal, accompanied by some noise. The brakes work, but they are not full strength.
In driving the vehicle to the mechanic, I had FULL brake pedal travel, all the way to the floor. My guess is that I scraped up crud and corrosion in the master cyclinder, and this is causing the problem. My questions:
1. What do y'all think?
2. Do you think that this might have messed with the calipers, too?
Any help would be appreciated.
