unabonked
- January 7, 2002
- Boston, MA
- 98Sport, 94XLT, 96Sport
My brake lights arn't working. I replaced the fuse and the bulbs... no go. The center lights is also not working.
I broght it into ford, who said it was due to some aftermarket lights i'm using. These lights are run off a relay thats attached to the foglamp assembilly. These work fine. Ford said they could dosconnect it for $300. I highly doubt this is the problem as the fogs and the aftermarket lights work fine. Arn't they completly indipendant of the brake lights anyway?
So now its down to two things as I see it... somthing is either dosconnected, or somthing is shorting, which I doubt because it would have blown the fuse.
What and where should I be checking for disconnections? Could it be the relay brake light relay? If so, where is the brake light relay located? I can hear that clicking sound when depressing the brake pedal, so I know the switch is still intact.
