yorksmick
- March 12, 2008
- wakefield
- 98 explorer
hi all ive posted this in the uk section in the hope that i might get an auto electrition,however the problem i have is that the no13 20amp mini fuse keeps blowing.i can change the fuse and it will be ok for a day or two then it blows again it can blow any time .i know when it has blown because i cant engage gears with the auto box before i move off.then when i change the fuse i can change gears move off and the doors lock ihave changed the break switch as i advised this could be the problem,it has happened since so i checked break switch which is ok i am baffled any help would be appreciated.
