RocFox
- July 11, 2021
- Chattanooga
- 2005 Ford Explorer Sport
My 2005 xlt had rear disk brakes. I just learned that the caliper uses two different diameter caliper pins. Can anyone tell me what is the correct placement of the larger or tighter fitting caliper pin? One is 14mm and one is 16mm. My caliper mounts to the rear so should the larger pin be at the bottom? Do you all agree with this video. Leading gets tighter pin and trailing get looser pin?
Thanks
Thanks
