Brake problem. | Ford Explorer Forums
Brake problem.
bcfixes
cartersville,Ga
I have a 93 explorer 2wd , I have bleed the brake system put a new booster on it and my pedal still goes to the floor. i have a good pedal at first then after the first pump the second goes to the floor any sugestions and thanks from a newby
brake problem
I am a newby here and have a problem with my 93 2wd explorer.I have a good brake pedal at first then after the second pump i have no pedal at all. I have replaced the booster and bleed the system. I can not detect any leaks in the lines . any sugestions and thank you in advance from a new guy
thank you for your info i will check that out in the morning:)
Did you replace the master cylinder?
Sounds like the master cylinder. Why did you replace the booster?
Welcome to this forum! I've moved your thread into the stock 91-94 section. Your master cylinder might be bad. Did you bleed all 4 points? You have to start with the wheel which is the furthest away.
brake problem
Juat wanted to say thank you to everyone that helped me with my brake problem. This is the most awsome site I have come across yet ,and look foward to helping someone else if possable with the knowlage I have. Have a safe and happy holiday season to all from bcfixes:us:
No fluid lose during this pumping exercise?
What made you replace the Booster in the first place?
