sgjii
- February 6, 2019
- Somerset, OH
- 2008 Sport Trac 2WD V8
I have been a hobby mechanic for many years and feel confident in my abilities. I have completed countless brake services in the last 20yrs on US Domestic, Euro and Asian. I have never experienced the heartache and issues like a 4th Gen Explorer brake system.
My first experience was a 2008 Explorer Sport Trac. I didn't even crack open the brake system but compressed calipers for removal and wheel bearing replacement. Afterwards, the brake pedal was spongy, and felt like it bled off and sunk with the engine running though solid without the engine running. I bleed and flushed the fluid to no avail. I ended up replacing the master cylinder and re-bleed and had the same results. After driving and getting the ABS to engage things felt a lot better but I always feel they are mediocre at best. That is when I learned about the ABS Service Bleed with a scantool. It made no better improvement than engaging the ABS. I have lived with the marginal braking for 20K miles...
Enter my next 4th Gen Explorer, a 2006 Limited V8 with 186K that I bought non-running. Got the running issues fixed and went to work on the metal on metal brakes. After new rotors and pads. I cleaned up the calipers and flushed the old dark fluid. Got out my NEW scantool with the ABS bleed function and went through the process. All should be great? Same crap as the Sport Trac only worse. Good pedal with engine off, spongy and badly sinking to the floor pedal, like the master cylinder was bad. Odd that the pedal would not bleed off like that with the engine off but it would if the engine were running.
I replaced the master cylinder had the same results of spongy sinking pedal. I said screw it and drove it anyhow... I was scared going down the driveway hill but it straightened up within a couple of miles on the back roads and has been fine for the next 100 miles. I am still baffled by it. I am starting to hate the 4th Gen Explorer brake system, it just shouldn't be that hard to service, bleed brakes and have a solid confident pedal. I now have 2 used master cylinders on the shelf that are likely fine.
Can anyone shed some insight? Is there something unique in the design of the system? Something I am missing? Some service procedure that cures this all right up?
I have not experienced this with my earlier Explorers 97, 98, 99 nor my Rangers 99, 03, 04 nor my GM, Benz, VW, Porsche, Audi, Jeep, Chrysler, Subaru to name some others I own/have owned..
Thanks, Stephen
Thanks, Stephen
