97Exploader
- October 18, 2008
- Chicora, PA
- 97 XLT
OK, I looked around with no luck so, I'm going to ask now...
97 X Has new brakes and rotors all the way around. All new brake fluid too. I completely flushed them. Rear calibers are new also.
Now Here the problem.. Brake are dragging. No, its not the brake stuck in the mounts or the pin's froze. I checked all that over till I was sure.. front calibers checked to make sure the moved with ease in and out. What I can't figure out is, when I drive it and they start to get hot, I come back and jack it up all the way around & there all tight. Really the front. I can open a bleeder and the all come loose again!?!?
You guys think it could be the ABS? or the master cylinder? Not letting the pressure off? When I open the bleeder it doesn't squirt out, it just comes out the bleeder a 1/8 in the goes to nothing?
What the odds of the brake hoses on both front making it do this? I'm up in arms about this.
Thanks for the help to the people that answer..
