Malchi
- August 6, 2010
- Ontario, California
- '91 X 4x4
Ok, I started this on the Band specification/Adjustment thread, but felt it needed a thread of it's own so as not to hijack that thread.
Anyway, I was adjusting the bands on my 1991 Explorer 4x4 trans and managed to break the OD band. I don't know if it was already bad (d0 they get weak after a while) or if I just never felt the torque wrench click and overtightened it. I have to admit, I have never torqued anything to 120 inch lbs before and was surprised to see how little pressure it took. Got my intermediate band adjusted right, after I learned my lesson on the OD.
Anyhow, thanks to BrooklynBay for the help so far, in advising me what that pop inside the trans meant when the bolt all a sudden started turning too easy. And for advising me not to drive it that way. I was gonna do so, thinking I just would'nt put it in OD.
Now, here is the reason I adjusted the bands in the first place. I just bought this truck a few weeks ago and, after replacing the fan clutch with a heavy duty one, I could hear the engine rev up more clearly. Going from a stop, it seemed like the tach was going up quickly and the speedo catching up slowly. Like, the trans wasn't grabbing very solidly. Also, when it shifted, at any speed, any gear, it seemed to only be droppig maybe 500 or so RPM. Just didn't seem right. But, I already stated to BrooklynBay that I know very little about transmissions. Also, last day or so, after I replaced the vacuum modulator, which was leaking like a sieve, it seemed at times, while driving, if I punched it, the truck would just wind up kinda high without really accelerating for the first second or so. To me that sounds like a slip, no?
So, hoping the band adjustment would at least help get me by a couple more years, I decided to do that.
Now, seeing as I broke the OD band, it needs to be replaced. I read a good bit of the thread about rebuilding the A4LD, and I am sure I could at least replace the OD band, and I think I could do the rest as well. But, I already have over $900 in this truck, and it's only worth about $1500 or so at best, I don't wanna put much more in it.
So, here are my options as I see them. I could R+R the trans and replace the OD band, and hopefully that will fix it. Or, I found I can get a used trans from the local U PUll It salvage yard for $200, and slap that in and hope for the best.
Can anyone, BrooklynBay?, give me some input on this? From the description of my symptoms, do you think replacing the band will fix it? What about a used trans? Is it worth it? What should I look for to see if mine is worth just slapping in a band, or in the used one to see if it is gonna last me a year or so?
I am planning to drop my pan this evening and see what it looks like in there.
