mezcalwest
- February 11, 2008
- Guadalajara Mexico
- 2000 XLS
Hello
all i know from the mechanic is that the problem is down there with the catalytic converter....aparently an 02 sensor giving the bad signal.... and then i discovered the leak.... .... catalytic converters are VERY expensive down here in mexico and i refuse to take them off and install a just a pipe instead... (as mech said) Note, there is 4 (four) cats. two small ones in the front and two bigger ones in the pipe after both pipes become one. the crack or leak is right in between the two big ones.
should i take it to scan again before fixing leak and see what the code is or... go straight to fix the leak in the exhaust
Thank you for followin and helpin.
