Build sheet? | Ford Explorer Forums
Build sheet?
Summerton,sc
91 explorer Eddie Bauer
My explorer was trashed before I bought it
while in the vacuum solonoid I found my
original build sheet but it was stuck to the floor from being soaked in water and pop and. Who knows what else
question I have is there a place to get a copy if I provide the vin? I want it for show purposes. :exp:
What vacuum solenoid? just curious..
Modulator ** on the transmission I rolled back the carpet to get to access panel and found the build sheet under carpet on drivers side front floor
oh I been under my carpet there before they didn't leave one for mine :(
You shouldn't have needed to go to that access panel to reach the vacuum modulator
The "tin" build plate is tied to the core support on the drivers side.
Pull the grill off to access. Has all the details: paint color, options packages, axles, yata yata.
It is only attached with a twist tie, mine was still there as the paint was also holding it in place.
No other way to get to it
I think mine is rivited but I want a copy of the paper that was under the carpet that is ideal
Its mounted on the side of the transmission. You can reach it easy from under the truck. I know the breather tube is on top though..
Trust me I tried I didn't wanna fight it from inside
