Jeremy- sorry did not get it done. I might go to his house sometime this week I will look at if I do.
410- I have been thinking about putting a new bigger cooler on as well. Does the stock one just not do the job or what? Where do I get a cooler, what do they cost, and what else will I need? Do they use the stock hoses and stuff or what?
I am still waiting on the Torque converter. It better be here by Friday because my friends all took Friday off.
Kirby, no biggy.
I can't even think about startin my SAS for a few more months anyway.. I don't have a garage to work in (it's tooooo short) so I gotta do it in a gravel driveway
which means I gotta wait 'til it starts gettin a little warmer than 25*F
AND ITS IN!!! I am excited! My truck is mobile again. It was a smooth install once I got all the parts required. We finished last night at 3:00 am. It has alot more power. It does, however, Shift a bit awkward. I don't know if I am not used to the shift kit, or it is the break in. The 3.06 first is very cool. It runs like 4.10s on the trail.
The one Hold up I have is the stupid thing wont go into 4low. Any ideas???? It clicks into 4 high, but does nothing into 4 low. Do you guys think it could be something to do with the neutral sensor? is there suck a thing? where is it located? Eveything on the transfer case seems to be plugged in. I want to see how it crawls Thanks.
If anybody needs to contact this guy, let me know.
make sure your your neutral safty switch has 5 pins. if it has 4 then you'll need to swap in a 5 pin. The #5 pin is a neutral signal for the low range.
Thank you brett... I will check. I can just unbolt it and slap the old one in right? That is probably the problem!
I found out why I thought it shifts wierd, now thaty the roads are dry. The shift points are at 4,000 RPM for just about every gear. It just feels awkward because it shifts alot less. I think it will be better for it since it shifts less. Man, it is alot faster. My Guy is ready to build some more, any Interest??????
I might be interested in buying one of those if they're shipping for $900-$1000 I'd like to have a spare A4LD ready to go in case mine craps out again. I had to pay $1025 for a rebuild on mine which is cheap compared to what the rest of you guys have said it has cost.
