try to reset the fuel pump inertia switch it is inside on the pasenger side on the firewall under the heater. pull your carpet down it has a plug going in the bottom and a reset button on top.
there is also relays that are under the power distribution box under the hood I can't remember which one it is but one of them is for the fuel pump and if it is bad there wont be any power to the inertia switch.
dang it man i have over thinking things, i pulled a ll th emaxi fuses uder the hood and didnt see a blown one, later came backw/ a test light and found the problem blown ecm fuse,repaced it and now runs!! hooked up the RIGHT WIRE on THE GREY pulg and i have 4 lo thanks to all for the input and help!!!!
