It wasn't distorted at all, i'm not an audio snob but i don't like trashy audio quality. The only thing is that it hits the max the stock speakers can handle earlier than if you bypass it so you cant crank your volume dial all the way. It only takes a wire nut to wire the remote turn on. Give it a try first to see if it bothers you, if so do the bypass, if not then you saved yourself some time.
Hmmm you bring up a good point.. I have a couple more questions now tho, haha.. Where do you connect the 12v amp turn-on wire (blue/white), into the red or yellow wire on the stereo harness? I actually already connected the amp ground into the ground on the harness before.. Then I have a blue wire right next to it for power antenna.. On the stereo harness I also have an orange auto electric antenna wire..
And just for clarification, I don't have to connect the illumination and dimmer wires right? In the past I never have, and everything has always worked fine..
EDIT: I just went out and connected the 12v amp wire to the power antenna wire like you mentioned, and it worked! And you're right, it doesn't sound bad at all, just definitely gotta be careful with the volume levels.. But I've already compensated for that by keeping the volume on my mp3 player lower, so you can put the stereo volume up higher.. It actually sounds better like that I noticed, and the only thing I'm gonna be using is the mp3 player.. The actual radio has always come in really ****ty, and it's the same with the new deck, but that's not an issue at all..
So thanks, you definitely saved me more time and money, and I'm fine with this now.. It was other threads I was reading where people were saying that it would sound terrible using the stereo and stock amp, and 1 guy even made it seem like you'd ruin the speakers instantly.. Well as we both know at this point, it's simply not true.. Before with the stock deck I was using the cassette player to connect to the mp3 player, and that definitely had some hissing, but now with a direct Aux input, it's gone.. So thanks again, I'm pumped..
