C1236 code with check advance trac message and abs/advance trac lights on dash | Ford Explorer Forums
Chemistrywhiz
2005 Ford Explorer
Left rear speed sensor input missing code is itermittant. Replaced sensor, wires look okay. What else should I check?
Can you check the wires from both ends?
"Possible causes
- Faulty Left Rear ABS Sensor
- Left Rear ABS Sensor harness is open or shorted
- Left Rear ABS Sensor circuit poor electrical connection
- Faulty Wheel Speed Sensor
- Wheel bearing"
Bearing?
Read more: http://engine-codes.com/c1236_ford.html#ixzz35ksXAl00
