Markaprice73
- March 20, 2012
- Texas
- '03 Sport Trac XLT (RWD)
Hey all, I just finished doing a beautiful front brake job. But, thinking back..I wondering if my caliper pins are in the right spots. I did the passenger side first. The slide pin on the bottom had the little rubber sleeve on it(im not referring to the boot). The top one does not. Then, on the drivers side...I pulled the pins out and the pin with the rubber sleeve on it was installed in the TOP. So I figured the place that did my brakes last mixed the two pins up. So, I put the pin with the rubber sleeve into the bottom hole.
Does anyone know witch way is correct??? Everything is working fine as far as I can tell and both pins slide very nicely. When I looked inside the hole that the pins go into, they both look the same with smooth walls. These are the factory pins btw still in great shape and yes one pin does not come with rubber sleeves on them on my 03 ST. I'm just thinking maybe they SHOULD be opposite? IDK.
