Welcome to the sight. There are not many ,if any, lifts for your 96. There are some for rangers that you can modify to fit. Your best bet if you are looking for a small simple lift is the torsion twist/shackle lift.
This is the same as a 2"suspension lift but will only cost you like $55 and take 1-2 hours. The torsion bolts up front can be tightened to raise the front (which is free) and the shackles go on the rear to raise the rear.
Man, Britt did you ever come to the right place! Look around here on the site there's plenty of information on what you're looking for. Many people have done the Ranger lift so you're sure to find information about it here. Just do a search. And welcome to the largest time suck in your life!
