LubeMan
- September 11, 2004
- Ephrata, PA
- '96 5.0 AWD XLT
Here's the deal, I have a '96 Explorer 5.0 AWD that has a constant check engine light on. I had the vehicle scanned at my buddies garage and these are the codes that I received.
P1400 EVP EGR Sensor Circuit Low Input
P0402 Excessive EGR Flow Detected
P0446 EVAP Canister Vent System Range/Performance
I have already replaced the EGR Valve Position Sensor and the EGR Vacuum Solenoid, with no luck. The check engine light comes back on after about 2 miles of driving after being reset.
The only other possibility I can think of is the actual EGR Valve is bad, but other than that neither I nor any mechanic I have asked has a clue as to what is causing these codes to trip.
If anybody has any idea what might be causing my problem I would greatly appreciate your input. I gotta get this CEL off so I can pass my inspection at the end of the month! Thanks!!!!!
